Brief Description: Opening canopy after windscreen fairing cure
Used tongue depressers to slide between the windscreen fairing layup and the canopy bubble to pop the laminate loose from the release tape. Once it was loose all the way around the canopy could be opened.
Started trimming the windscreen upper faring.
Installed some blind rivets at the LH and RH base of the windscreen upper fairing
