Removed the canopy skirt and applied some micro/epoxy to the gap between the skirt and bubble at the very aft end. Re-cleco'd the skirt back in place for cure
Drilled, deburred, dimpled scuffed cleaned and primed the components for the baggage door.
Cut the hinge halves to length and match drilled the outboard one to the outer skin inboard angle.
Riveted the outboard rib and inboard angle to the outer skin
