Brief Description: Forward section and started center section
Riveted nutplates to the lower baggage compartment bulkhead and the outboard baggage floor attach angle.
Clecoed the firewall to the forward floor and match drilled the holes common to the floor and bottom firewall angle.
Started on the center section. Drilled the 5/8 inch holes for the rudder cables in the forward and aft center section bulkheads.
Fabricated the seatbelt lub spacers and the forward control mount.
Fluted the LH and RH center section vertical bulkheads.
Clecoed the forward vertical bulkheads to the forwar centersection bulkhead and match drilled the 1/8" holes. Drilled, and countersunk the holes for the nutplates in the forward center section bulkhead.
