Brief Description: Wingtips part 23 and some electrical work
Applied epoxy pinhole filler to the top side of the wing tips
Worked out the routing paths for the wires that will go through the firewall. Rerouted the RPM wires from the SV-EMS-220 to the mag switches (per the Skyview installation manual).
Rerouted one of the SV-EMS ground wires to the bundle of ground wires that will terminate at the firewall ground block.
