Moved the LH wing to the wing cart and mounted the RH wing in the stand.
Installed the LH inboard wing skin to wing rib rivets using an squeezer. Intalled the LH bottom wing skin to flap brace to flap hinge rivets using the squeezer. Installed the LH flap by installing the hinge pins.
