Cut the W-818 (short) pushrod tubes to length, laid out and drilled the rivet holes through the tubes and end fittings. Poured liquid primer in one end, rolled the tubes as the primer flowed to the other end and left the tubes at a slight incline to allow the excess primer to flow out before the primer set up.
