Brief Description: RH aileron prep and prime and RH bottom wing skin
Scuffed, cleaned, dimpled and primed the RH aileron spar and end ribs.
I realized the other day that although I'm not ready to rivet the bottom wing skins on, I should get them deburred, dimpled and primed because they're too big for my paint booth and the weather is turning colder and windier so priming it outside will be more difficult if I wait until I'm ready to put the skins on. So I started the prep process for the bottom skins
Stripped vinyl from the rows of holes on the OML side of the RH bottom skins and removed the vinyl from the IML side.
Deburred the rivet holes on the OML side of the inboard bottom RH ski
