Brief Description: Wing cart and aileron bracket installation
Took the LH wing down from the wing stand and put it on the work bench. Moved the RH wing to the LH stand. Disassembled the RH wing stand and used the materials to build a wing cart per the Van's plans. Placed the RH wing in the cart.
Riveted the aileron brackets to the LH and RH wings
Clecoed the aileron gap fairing to the LH wing and match drilled the holes. Removed the fairing and dimpled the top wing skin.
Trimmed the LH wing flap brace to clear the rear spar reinforcement doubler.
