Brief Description: Fitting aileron brackets to wings
Removed the trailing edge root end support brackets from the wing stand and the outboard wing root to make room for the outboard aileron brackets.
Fit the aileron brackets to the wing aft spars which required filing radii on the aft edges of the brackets to match the radii on the aft spars so that the brackets fit flat against the spars.
