Dabbed proseal on the shop heads of the rivets holding the upper RH skins to the top flanges.
Installed the vent line in the RH tank. Clecoed the inboard rib to the tank skin and threaded the vent line to the AN fitting in the inboard rib. Bent the outboard end of the vent line to fit in the clip riveted to the cap flange. Marked and cut (with a dremel cut off wheel) the outboard end of the vent line to fit inside the outboard rib with a 1/4 inch clearance.
