Match drilled the RH fuel tank inboard attach zee to the spar. Installed nut plates in the spar. Placed the fuel tank on the RH spar. Pushed it outboard against the leading edge, strapped the tank down and match drilled the holes through the inboard rib and baffle into the inboard attach zee. Removed the leading edge and match drilled the holes from the outboard rib into the outboard attach zee. Removed the tank, removed the baffle and installed it in place on spar, clecoed to the inboard and outboard attach zees. Match drilled the remaining holes through the web of the baffle into the attach zees.
