N983LK
Date:  8-10-2014
Number of Hours:  3.00
Brief Description:  Riveting HS and drilling deburring VS
Riveted inboard and outboard edges of LH HS with squeezer. Started to rivet center forward rib to RH skin but over drove one rivet. I removed the rivet but the hole was out of spec so I ordered an assortment of “oops” rivets from Vans to fix it and for future screw-ups.
Work is shut down on the HS until I get the oops rivets, so I went back to working on the VS. Drilled the holes in the rear spar to spar doubler to hinge brackets. Started deburring the VS ribs.
