N983LK
RV-8
Propeller dynamic balancing
Had the prop/engine combination dynamically balanced. The baseline vibration level was .15 inches per second. After adding the balance weights it was down to .01 which is about as good as it gets.
Accelerometer/RPM sensor bolted to engine
Test set up - note tail tied down
The results - .01 IPS
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
