Switched the two white wires on the pitch trim servo to reverse the polarity. The pilot's stick trim switch function is now correct. Reset the Skyview trim widget.
Removed the vertical stabilizer to allow easier access to the elevator center bolt.
Installed the elevator rear push rod. Installed the elevator horn bolts and spacers. Reinstalled the vertical stabilizer. Torqued and torque striped all nuts.
