Secured the engine temperature sensor wire bundles to the engine mount frame with adel clamps
Riveted together the LH and RH front baffle assemblies
Began fabricating the baffle seals. Cut out seals for the aft and LH baffles. Drilled the rivet holes in the baffles. Used a hole punch to cut the rivet holes in the seals. Clecoed the seals in place.
