N983LK
RV-8
Baffles part 37
Installed the LH rear baffle on the engine.
Bolted the oil cooler in place on the LH aft baffle.
Rerouted the engine sensor wire harness to provide additional clearance from the oil cooler.
Began routing the RH EGT and CHT wires
Oil cooler installed
Rerouted sensor wires
RH EGT and CHT wire routing
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
