N983LK
RV-8
Baffles part 7
Drilled a 1 inch hole in the RH inlet baffle and support angle for clearance of the propellor oil line.
Deburred the components for the inlet baffles.
Riveted the air damns on the inlet baffle support angles.
Attached the inlet baffles to the engine.
RH inlet baffle
Hole for prop oil line
LH inlet baffle
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
