N983LK
Date:  11-15-2020
Brief Description:  Wheel fairings part 7
Removed the wheel fairings again. Applied some epoxy/flox to the LH fairing at the two holes that mount it to the Inboard bracket. Applied packing tape over the epoxy/flox and reinstalled the fairing.
Removed the RH fairing. Tried something different for the liquid shims on this side based on what other builders had done. I drilled a series of holes near the mounting holes, reinstalled the fairing and used a syringe to inject the epoxy/flox through the holes to fill the space. We'll see if this method works better.
