N983LK
RV-8
Riveting canopy
Removed the canopy skirt and canopy bubble. Did final sanding on canopy edge
Replaced bubble on canopy frame.
Cut sections of model airplane fuel line to match the canopy thickness of each hole and glued the cut pieces in the holes with super glue.
Clecoed the canopy skirt back in place.
Installed the blind rivets common to the canopy skirt and bubble starting from the aft end and working forward.
Installed the blind rivets that secure the skirt to the rest of the frame.
Shaved down the heads of the rivets
Applied epoxy/flox over the heads of the rivets.
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
