N983LK
RV-8
Sanding the micro on the windscreen
Sanded the micro on the windscreen. Used a section of a 4 inch diameter yoga roller as a sanding block for the micro around the lower front edge.
Applied another layer of micro to the lower front edge.
Sanding block
First coat sanded
Second coat applied
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
