Brief Description: Seat heat wire, harness clamps and floor paint
Installed Adel clamps on the click studs bonded on last work session. The Adel clamps support the main wire harness in the avionics bay.
Began running a 14 gauge wire from the VP-X Pro to the RH gear tower. It will eventually run down the gear tower and aft through the spar where it will be coiled and stowed. The intent is to hook up seat head to it in the future (update: this wire was later removed)
Masked and prepped for paint an area on the RH cabin floor where the rear passenger's feet will run with they enter and exit the aircraft and if the pull their feet back during flight. Painted the area with truck bed paint. Let dry for an hour and removed the masking.
