Brief Description: Rear stick CPC connector - Airplane side
Riveted the rear stick CPC connector bracket in place.
Terminated the wires that run from the CPC connector to the forward avionics bay. Installed D-Sub pins. Inserted the pins the a CPC receptacle and installed a back shell. Fastened the receptacle to the bracket.
Rear stick CPC receptical mounted to cabin floor rail
