Temporarily hooked up the Skyview display to the battery to power it up. Played around with some of the setup screens (including putting in the N number for my airplane). Everything seems to work properly although none of the other parts of the system are hooked up.
Opened up the 37 pin D-sub harness and tried to remove one of the pins but the pin extractor wouldn't work for some reason. I had planned to pull out some of the pin/wire combinations that came with the Skyview display wire harness and replace them with wires from the other system components such as the ADSB and transponder. Since I couldn't get the pins out I decided to splice the wires in the SV display harness to the wires coming from the other components. Reassemble the D-sub harness.
