Solder spliced one of the wires from the start switch on the stick to a pre-terminated wire from the VP-X Pro kit and connected it to the VPX-Pro.
Installed wires (with pre-terminated VP-X connector pins) in the VP-X pro connectors for the power wires for the Garmin G5, CO guardian and alternator field. Labeled each end of all the wires.
