N983LK
RV-8
LH Com 1 antenna doubler riveting
Dimpled the rivet holes in the fuselage skin for the com 1 antenna doubler using the close quarters dimple die set.
Back riveted the doubler in place using the back riveting bucking bar supported by a floor jack. Had to reposition the jack for each rivet.
Installed the Adel clamp on the antenna doubler reinforcement angle to hold the wires and tubes clear of the LH aileron push rod.
Back riveting bucking bar supported by floor jack
Rivets installed
Wires and tube secured
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
