Deburred the rudder pedal lock components. Riveted the lock mechanism together. Cut the bottom off of the rudder pedal lock pin and installed the roll pin. Installed the release cable, inserted it in the pull handle and tied the know. Bolted the rudder pedal assembly in the fuselage.
