Replaced the hex head AN3 screws holding the fuel valve in place with stainless button head 10-32 screws which look much better.
Match drilled the aux fuel pump bracket and the cockpit floor. Deburred the holes and countersank the inside of the aux fuel pump brackets. Fastened the bracket to the floor with blind rivets.
Mounted the aux fuel pump to the bracket with the supplied hose clamp.
Began forming the fuel line that will go from the fuel valve to the fuel filter but discovered that the tubing bender that I have will only form 90 degree bends and I need to form a 180 bend, so I ordered a better bender that will do 180 degrees.
Fabricated a template which can be clecoed in place on the aux and lower forward longerons to identify where the hole in the side skin for the fuel tank lines will pass into the cockpit. This will be used as an aid in forming the tank lines.
