N983LK
RV-8
Longeron drilling
Long, productive day. Scuffed, cleaned and primed the replacement F811 bulkhead parts.
Drilled the lower and auxiliary longerons.
Match drilled the upper longerons to the top row of holes in the forward and mid side skins.
Final drilled the remainder of the 3/32" and 1/8" holes in the two forward side skins and the RH mid side skin.
Doesn't look like a lot when I write it out but there were an awful lot of holes!
RH upper longeron clamped to the engine mount bracket
Drillilng the aux longerons
All holes in the LH forward skin drilled.
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
