N983LK
RV-8
RH center section side skin assy and joining front
Used a fly cutter to cut the 2 5/8 inch holes in the RH center section side skin and RH OB center section rib for the reat seat vent hose.
Clecoed together the RH center section side skin assembly.
Final drilled the #30 holes in the center section per to instructions.
Clecoed together the forward and center sections.
Cutting the vent hose hole in the side skin
Center section and forward section celcoed together
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
