N983LK
RV-8
LH tank leak check and RH spar prep
Leak checked the LH fuel tank with soapy water. No leaks found. Set up the tank with a manometer to monitor for a week.
Countersank half of the rivet holes on the RH spar top flange.
Soapy water leak check
Manometer set up for LH tank
Measurement from original mark
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
