N983LK
RV-8
More fuel tank work
Bent and cut the wire for the LH fuel tank fuel level float and installed it in the sending unit.
Installed the RH tank fuel pickup tube and torque it's B nut in place Final drilled the fuel pickup anti rotation clip.
Trimmed, scuffed, drillled, deburred and dimpled the replacement stiffener for the LH tank.
Prosealed replacement LH tank stiffener and backdrilled it in place.
Prosealed LH anti-rotation clip and riveted it to access plate.
Dabbed proseal on shop heads of just installed rivets on stiffener and anti-rotation clip
Applied proseal to remaining two OB rib aft corners and clamped the aluminum forming strips (see 6/11/15) to form filets in the corners.
LH tank fuel level float installed
LH fuel pickup anti-rotation clip
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
