N983LK
RV-8
LH LE prep
Dimpled LH leading edge ribs. Drilled LH spilce plate for nut plates and dimpled LH splice plate. dimpled stall warning switch access cover doubler. Primed LH LE ribs, spice plate, stall warning access cover doubler and stall warning switch support bracket.
Deburred LH LE skin, scuffed and acetone wiped.
Installiing nutplates on LH splice plate
Scuffing the LH LE skin with random orbital sander and scotchbrite
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
