N983LK
RV-8
RH wing LE inbrd rib
Drilled hole for tie down ring in RH LE.
Clamped and drilled RH LE inboard rib in place and backdrilled through LE skin and spar
Removed inboard rib, clamped splice plate in place and back drilled through LE skin. Removed splice place then assembled rib and splce plate to LE skin and spar
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
