N983LK
RV-8
Rudder priming and finished VS
Fit up the rudder tip cap. Drilled and dimpled the holes. Disassembled the rudder, cleaned and primed spar, ribs, horn and horn support.
Riveted the rear spar to the vertical stabilizer. The vertical stabilizer is now complete.
Primed rudder parts
Finished vertical stabilizer
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
