The fuel hoses are not provided in the kit. I chose to use stainless steel reinforced flexible fuel hose material. I purchased fuel line hoses material and fittings from a performance auto shop. Their technition taught me how to install the AN fitting on the hose ends by doing one for me at his shop. I later cut the materials as required to fit the various sections of the fuel system conecting the fuel valve and the gascolator and the fuel flow cub and the aerocarb injector.
I also chose to install a fuel cut-off cable which can be opperated easily from the panel. It provides an advantage to visibly see when the fuel valve is off (pulled out).
