Torqued the hex head cap screws on the end of the rocker shaft assembly to 25 ft-lbs. Screwed in the mounting studs and inserted the O-rings. Used one spacer on the mounting studs and mounted the rocker assembly on the mounting studs. Adjusted each swivel head assembly to 1.5 turns back to allow for future adjustment space. Verified the proper seating of the swivel pads on the valve stem.
Prepared for the next step which is to measure for the push rod lengths.
The rocker arms go on and off several time during the processes.
