I reviewed the video instruction and then read and followed written istructions,
It is best to have a helping friend to accomplish the torquing process.
Aligned the machined dot on the face of the Cam Gear with the slot in the Cam Shaft. Applied Red Locktite to the bolts. Installed cam washers and boltsper the instructions and torqued to 20 ft-lbs. Polished off rough edges on Cam around stamped numbers to avoid potential interference between the Cam and the Connecting Rods..
