I purchased the optional pre-assembled crank shaft. So I did review steps 1 - 9 of the Crankshaft Assembly instructions and looked closely at the pictures in the manual comparing them to my Crankshaft. After doing so I was able to go to step 10.
Installed Prop Hub Bushing and torqued to 80 ft-lbs. Had to go to Lowes and buy some bolts to use to hold tention for torquing.
Assembled prop hub and connecting rods
Connecting rods
Case halfs and assembeled crankshaft and connecting rods
