Assembled mixer and installed as per details on plans.
The holes in the powder coated parts needed to be drilled so that the appropriate hardware would fit properly.
The mixer was assembled on the table and then installed in the aft fuselage. I ended up using slghtly larger washers on top. The ones called for in the plans were conflicting with smooth movement of the Ruddervator Push Rods.
