Installed the male-end of a 5-pin waterproof connector on length of 8-wire cable qnd matchjing female-end to the 4 wires of the elevator trim servo cable. Cable connector will be located in the aft fuselage (added to aid installation/removal of h. stab & elevator structure mating to fuselage). Added the male-end of a 2-pin waterproof connector to 2 of the remaining 3 wires in the 8-wire cable and matching female-end to the 2 wires of the tail-light assembly ready for mounting in the rudder. The last wire (8th, orange) of the cable is un-used. These connectors work well in marine applicaions and I have several more 2-pin connectors to be used in installing the wing-tip navigation/position lights, angle-of-attack sensor, fuel level transmitters, and possibly a landing light.
