Brief Description: Final installation of elevator horn
Final placement of elevator control hore mating elevator to h. stab. Completed everal bracing structures on top and bottom of both h. stab and elevator. All a5 rivets. Laid out positioning of outer hinge locations. Drilled hing pins (tough job: 1/16" dia hole in 3/16" dia pin). Primed and painted 4130 steel hinge pns, and installed on outer elevator ribs with A5 rivets. Outer hinge plates on h.stab will be drilled out and riveted (A5) at a later time to facilitate disassembly of the structure for mounting to aft fuselage.
