Spent just a few hours this weekend adding the two rear L-Angle diagonals to the sides of the fuselage. Two more to go ...to the rear bulkhead...
Also working on Cream D Mint airplane, after doing some taxi testing....more to do here before getting this aircraft airborne....brakes seem a little weak so need to bleed them and some other stuff...
Been doing some adjusting and tweaking on little green plane, like the seat back which needed to be modified slightly to allow for the longer legroom that i needed to fit comfortably in the cockpit space which is small and fits me like a glove Now. Taxi tests to follow while I wait for the new tachometer to arrive....little by little getting closer to commiting aviation...
Still working on diagonals at the rear of fuselage
More of the same...
Not yet airworthy until some minor stuff done like bleeding the brakes etc...
