Secured NEG (-) battery cable slong R side rib walls. Installed ground power relay onto battery tray. Manufactured ground power to battery master relay jumper. Modified snap bushing to fit inside 2nd snap bushing for battery cable firewall exit. Added lug and heat shrink to starter solenoid battery cable. Drilled F-801HL-1 vertical firewall support for starter solenoid attach points.
