Attached battery master solenoid to battery tray. Manufactured POS (+) battery cable from lug to battery master relay. Drilled hole in L gear tower for pitot and AOA lines and installed snap bushing. Installed master relay to starter relay POS (+) battery lead. Ran negative battery cable to forward avionics bay. Drilled firewall for grounding block.
