Brief Description: Building trim tab / Finishing the elevators
Clecoed trim tab back together. Rivet the bottom of E-619-1-020 trim tab skin to the bottom flange of E-607PP trim tab spar and E-717/718 trim tab horns. Removed clecos along top flange of E-606PP trim spar and clamped E-721 trim tab hinge to the top flange and aft edge of E-701L skin. Trim tab and hine aligned with L elevator. Match drilled forward protion of E-721 hinge. Removed E-721 hinge and trimmed the inboard edge to match the E-701-L skin inboard edge. Re clecoed the tab hinge and trim tab assembly onto the elevator. Rivets set on top side of trim tab. Riveted ends of trim tab with blind rivets. Riveted forward half of E-721 trim tab hinge to the elevator.
