Brief Description: Prop governor and fuel fittings
Installed prop control cable onto governor. Installed nuts and lock washers onto governor stud bolts. Placed anti-seize compound on both sides of the gasket. Cleaned both surfaces and installed prop governor. Installed VA-128 restrictor fitting onto KB-090-T fuel pump T fitting. Installed VA-136 fuel supply hose from pump to fuel injector.
