Temporarily clecoed the hinge brackets to the rudder spar to check the fit. Rivited on the spar caps, rudder horn and the remaining ribs. Had to do the bottom rib with the rivet's factory head on the rib side because when done the other way, it caused puckering and seperation of the rib from the rudder horn.
