Final drilled and dimpled the forward VS for platenuts. Riveted in all the platenuts. Took three tries to tirm enough front the skeleton ribs so there would not be any interference. Riveted the skins on. Some holes required reaming so the rivets would go in. Finally attached the top hinge and torqued down the bolts.
