Joe's OneX #129 Project
Date:  9-15-2013
Number of Hours:  5.00
Brief Description:  Fit left OB wing skins
Pilot drilled the left OB wing skins, middle and outer to the wing frame. Updrilled the holes from the center spar to the trailing edge to #30 holes, left the holes forward of the center spar at #40. I have not yet decided what dimple dies I'll use on the flush rivets forward of the main spar so for the time being I will leave these at #40. I need to make some sample dimples in some scrap aluminum to see what works best. I have ordered a couple sets of Sonex dimple dies which I will also be testing.
Will probably work on the left wing tip untill I get the Sonex dimple dies and make some sample dimples. I plan to make the wing tips removeable using #4 screws and nutplates. I used this combination on my RV-9 and it worked well, Cleaveland tool sells a kit for $69 that includes the nutplates, screws and soft rivets. I want the tips to be removeable in case I decide to add lights at a later date. Also, I will be building the long wing tips which I think will not fit through a 7 foot high garage door when folded. I don't plan to be hauling the plane home but do want the option to store it in a garage if needed thus the tips need to be removable.
Left OB wing fitted
Left OB wing fitted
