Brief Description: Installed new OB root rib attach brackets
Installed the new rear attach brackets for the OB root ribs both left and right. The new brackets fit well and provided the proper alignment from the rib flange to the rear spar flange so the skin should now fit properly. The new brackets I made also provide better edge distance for the 4 AN3 bolts. I also used thin washers on the AN3-5A bolts since the bolts with standard washers and locknuts were slightly short.
